2003 xj8 4.0 base 2001 modified
Improved secondary timing chain tensioners were installed in the AJ-V8 in mid 2001. The best way to determine what was originally installed is to check by engine number.stamped on the front upper part of the cylinder block.
The earlier Nikasil treated blocks are actually more durable than the later steel sleeved blocks if the correct fuel is used. The engine number can also be used to determine if the engine is fitted with steel cylinder liners.
JagRepair.com - Jaguar Repair Information Resource.
The main cause of Nikasil failure was due to excessive sulphur in the fuel. If the engine has a Nikasil treated block and is still running, there should be no issue as fuel sulphur was reduced years ago in most countries.
motorcarman (02-17-2023)
