2003 XJ8 engine warning light
Guest
Posts: n/a
I just got an amber Engine warning light on my XJ8 2003. I checked engine fluidsand found oil a quart low. I put in a quart but light still exists. How do I reset light or explore if I need to take more into consideration?
Thanks for your help in advance.
CRC
CRC
2004 xjrs, check engine light is amber/valet mode
just car this car a week ago, i was using the green key commuting with it , i pushed the valet button, the car stayed in valet mode, i tried to unlock the trunk with the black key, no luck, i tried to lock the car and unlock it with the black key, no luck, finally I had a spare black key, i used it and was able to get it off the valley mode. still the first black key wont work . Also the check engine light amber color came on after I had pressed the valet mode button while driving the car with the green key. help............................
there is no connection between the ewl on and the valet mode. you have done nothing wrong by pressing the valet mode. on some models you need a code to get the car out of valet mode. the ewl is a deeper problem caused by the power train system. have you got any messages on the dash (ie restricted performance or gearbox fault) most common causes on those cars are air induction leaks and 02 sensors. i have also had a few thermostat bring up a ewl as well and when removed found the outer seal incorrectly positioned
tanios (04-06-2012)
thank you
I was reading another post same car and same mileage, they were changing,spark plugs,wires,sensors, not for nothing i believe"if it's working leave it alone"
thank you again.
thank you, u helped me pin point the problem, sorry i didn't reply back regarding a message with the amber color "restricted driving", it was only the amber light on with no messages, so next morning i retightnened the gas cap and the light vanished.
thank you again.
thank you again.
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
