2003 XJ8 - Which keyfob to buy?
I've researched and researched and I am finding it super frustrating to find a replacement key fob. I have the LNC2600HD SLM unit that states 315 mHz.
My car did not come with any fobs and my Launch X431 scanner will not connect to the SLM as it states "Secure access denied".
Ive tried several models including Ford's 315 mhz. When searching my XJ8's year I find only the flip key fobs available.
Is there a model number of any key fobs I can search for to find one that will work with the headlight/ignition programming sequence?
F59525 is the last X308 so it is a 2003MY and the North American market uses 315mhz rolling code from VIN F20645.
Different countries/markets use different frequencies.(NA did not use 433mhz in the later cars)
Apparently the (FCC I.D.) keyfob transmitter CWTWB1U322 will work with the cars from VIN F20645.
https://www.amazon.com/Expedition-Ex...07B2Z1QV5?th=1
Thanks for the info. I ordered it. It'll be here tomorrow. I'll let you know if it works.
I have these here currently from another recommendation on another forum but the car doesn't respond to them during programming.
Amazon.com: 2 KeylessOption Replacement Keyless Entry Remote Control Key Fob Clicker Transmitter - Black : Automotive
motorcarman (06-27-2024)
I bought the pair from AMAZON for about $10 with tax and they configure fine to my 2001 XJ8.
The red horn button turns the headlamps on just like the original Jaguar transmitter button in the same lower left location.
North American 315mhz 'rolling-code transmitter' should work on all 2001MY> X100 and X308.
Wish I could find a generic transmitter for the 1997-2000MY X100 and 1998-2000MY X308.(LJA2610AA)
57loboy (07-24-2024)
The pin that connector snaps to is stuck in the connector. Looks like the solder failed? How would I reattach the pin to the window?
Even tho, the remote should work when right next to the cable and it doesn't.
My connector isn't attached to the window.
Looks like the pin that is normally attached to the window separated from the window at the solder joint and is stuck in the connector.
I will reattach it with some conductive glue. Also, shouldn't the remote still program even if placed right next to the connector during the process? Because it's not working.
I replaced my SLM today with the same LNC2600HD model. Still doesn’t work with the fob listed above.
I did notice that there’s a red price sticker style label on both the new and old SLM’s that has a 98 date on it. Would this be an indicator that my SLM was made in 1998 and would need an earlier model 315 MHz remote?
I repaired the window antenna with some conductive window defroster tab glue.
