2003 XJR Audible Alarms for.....
Hi everyone, my first post.
I've used the "search" tab but haven't found an answer to these questions.
1)The audible alarm for my "Turn Signals"and "Open Door" with key still in the ignition switch doesn't sound anymore.
Where is this alarm? And in your opinion what's wrong and how to fix it myself.
2) The Reverse back up sensor Alarm sounds once when the gear selector is place in R, then stops sounding. No sound as rear bumper closes in on an object. The system worked fine when I purchased the car several years ago.
Thanks guys for your help and I look forward to meeting some of u a a local GTG in the future.
Cheers!
Cheers!
The x300's used a small speaker inside the steering column -- very easy to get to as all you had to do is remove the lower cover. I believe the x308 uses the same system -- although the sound is different.
I have an x308 but I have never had any problems with the "sounder" but I replaced the one in my x300 with a small speaker from Radio Shack. I was not able to get the exact ohm or size -- went with a slightly smaller speaker and an ohm that I was told on an electronic board would work -- I forget now if you want to go higher or lower. Speaker was less than $5. The OE replacement module was not all that expensive at something like $50.00 -- but it was backordered - so I fixed it myself.
I do not know what makes the back up sound -- I will take a listen next time I drive it.
I was not clear above: The speaker in the steering column is very small and it was common for it to burn out -- you can not tell it is defective just by looking at it. I had a small speaker in my workshop so I was able to attach it to the module to test if the module was OK -- Then I went and purchased a speaker that was small enough to fit. The speaker is the size of a quarter!
dsetter (03-01-2011)
PROBLEM SOLVED.. at least the turn signal auditable alarm issue.
Damn the cold.. turned on the heater and replaced the speaker.
Found an old stereo speaker tucked in the back of a closet.
Before I took it out of it's housing I connected the leads to the leads in the car.
Oh yeah baby.. stereo turn signals.. LOL!!!!
Love this place!!!!
Thanks for your help.
Love this place!!!!
The beeping in my 99 XJ8 comes somewhere from the front left of the car.
Definitely not from the parcel shelf in the back.
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
David
Reverse issue not fixed just yet.
I still get the 6 to 8 sec fault sound when I place the shifter in R. I'll get my ear close to the bumper for a listen next week when the temp really does warm up. Right now I'm afraid my ear would stick to the sensors like a wet tongue to cold metal pole.. :-)
The turn signal sounder/speaker is in the steering colum. I replaced the speaker to fix that problem.
My R sounder seems to come from the passenger side rear deck. It's fine... I'm sure I have a sensor issue.
Last winter I hit my sensors with a high pressure washer while I was blasting off the salt. I'm sure that's what killed it.
I've lived without it for a year... but I'm bored and want to fix those little things that mean a lot.
Moral of the story: Do not go reading posts about things that are not broken, it may make them that way.
kabs3012
09-12-2015 10:40 AM
