2003 XJR Fuel pumps not working
#62
#67
#68
The following 2 users liked this post by Parker 7:
03_jaaag (09-01-2024),
motorcarman (09-01-2024)
#69
That makes sense i was wonder why theirs coolant going into the throttle body. The leak was coming from the fuel line that connects to side of FPR and runs under the throttle body/supercharger.
#72
The following 2 users liked this post by Addicted2boost:
03_jaaag (09-02-2024),
#73
just tried the method of flooring it and cranking and still nothing. pulled the plugs. and ordered a syringe with a tube. gonna try to put some oil in each cylinder without making a mess. jump starter relay, put plugs back in and see if she starts up tomorrow. did find out that i didn’t tighten the left hand side plugs fully
#74
Battery chargers are not reliable in the things they display
You can prove this after a couple of hours with a independent meter on the battery post
03_jaaag (09-03-2024)
#75
There is a specific ignition labeled relay to put 12 volts " sitting " on the coils at all times ( the ECM provides timed grounds on the 8 independent return wires for current / spark )
If the relay is closing but there is a splice in the wire between left and right banks ( at least I thought on earlier X308s before engine / engine wire harness change ( AJ26 to AJ27s ) )
See page 58
There is a question on 2003 and 2003.5
The 2003.5 does have a additional single capacitor ( vs. 2003 ) for all 8 coils but no spice between the left and right banks but a splice for all 8 coils ( hint )
X300 01/E COVER (jagrepair.com)
See page 58
#77
Do you know of a gauge kit that’ll fit the schrader valve on SC engines? i bought a gauge and adapter from M.Stojanovic but it was lost in transport
#78
See page 58
See page 58
#79
Well im stumped again.
First video is before FPR replacement, it ran when i added a tablespoon of marvel mystery oil in each cylinder.
Edit won’t let me add video
Second is after FPR replacement same MMO in each cylinder and she won’t fire up. tried with the gas pedal down method and nothing. My friend was telling me it could be bent rods or valves. I’m ready to take it to a shop for a diagnostic. Anyone have any advice before hand of what the culprit could be?
Parker 7 (10-04-2024)
#80
