2003 XJR Fuel pumps not working
#62
#63
#67
#68
The following 2 users liked this post by Parker 7:
03_jaaag (09-01-2024),
motorcarman (09-01-2024)
#69
That makes sense i was wonder why theirs coolant going into the throttle body. The leak was coming from the fuel line that connects to side of FPR and runs under the throttle body/supercharger.
#70
#72
The following 2 users liked this post by Addicted2boost:
03_jaaag (09-02-2024),
#73
just tried the method of flooring it and cranking and still nothing. pulled the plugs. and ordered a syringe with a tube. gonna try to put some oil in each cylinder without making a mess. jump starter relay, put plugs back in and see if she starts up tomorrow. did find out that i didn’t tighten the left hand side plugs fully
#74
Battery chargers are not reliable in the things they display
You can prove this after a couple of hours with a independent meter on the battery post
03_jaaag (09-03-2024)
#75
There is a specific ignition labeled relay to put 12 volts " sitting " on the coils at all times ( the ECM provides timed grounds on the 8 independent return wires for current / spark )
If the relay is closing but there is a splice in the wire between left and right banks ( at least I thought on earlier X308s before engine / engine wire harness change ( AJ26 to AJ27s ) )
See page 58
There is a question on 2003 and 2003.5
The 2003.5 does have a additional single capacitor ( vs. 2003 ) for all 8 coils but no spice between the left and right banks but a splice for all 8 coils ( hint )
X300 01/E COVER (jagrepair.com)
See page 58
#77
Do you know of a gauge kit that’ll fit the schrader valve on SC engines? i bought a gauge and adapter from M.Stojanovic but it was lost in transport
#78
See page 58
See page 58
