2003 xjr radio and antenna not powering up
Question: is there an in-line fuse behind the dash for radio power, i hope not, I do not want to pull the dash apart. I do not see any request for a code to be keyed in for the radio either, was this a requirement for this on a 2003 xjr sold in USA? I did check the fuse #9 - 10amp under left footboard and one in the trunk 30amp, they both look fine. Help please, Brian
Received 1,796 Likes
Welcome bfinnega, please introduce yourself in the New Members Area under the General Jaguar Forums.
Your antenna motor is probably toast, meter the lead at the antenna, it unplugs.
Here is what I did with mine when I didn't want it going up with the radio on. I use SiriusXM almost exclusively and have a 3rd party head unit... https://www.jaguarforums.com/forum/x...ve-one-103359/
abonano
04-18-2017 06:11 PM
