2004 XJR won't start
It was running fine just a few days ago. No work recently. Was supposed to get serviced tomorrow but I won't be able to make that. I ran the car through a wash, which I almost never do, then took the car home and covered it. If this was water related it should have dried by now. This isn't the first time this happened.
The engine ground cable from the bell housing to the chassis may be at fault. Disconnect and clean. If it's not that maybe the starter connections. Unfortunately, there are many other possibilities. My question about the check engine light was an error. If the engine doesn't start it will be on. It may come down to testing all the fuses, solenoids and connections.
Jay bizzy
04-22-2019 10:21 AM
Mike Leon
General Tech Help
10-07-2017 05:24 PM
xjrwithproblems
11-22-2010 11:57 AM
