4.0 motor heads and bolts firing order
I have not been able to find anyplace that talks about the heads and head bolts on line. Wondering what is the correct procedure to remove and reinstall the heads on my 4.0 Jaguar motor. Do I have to replace all the head bolts or can I use the same ones. When I put the bolts in what is the pounds to tighten them to and is there any special order to tighten the head bolts down.
Another thought what is the firing order when I do get to put the motor back together. Have seen some talk about a A and B sides which is which and where is number one (1) at?
Are there and manuals to help me to do it right? I am not strong in this area but I am mechanical inclined just have never taken a motor down this far before myself.
Thanks for all the help folks
Received 6,313 Likes
timsalyer (11-22-2013)
The last TSB that I can recall from my 'Dealer-Days' was the XJ40/X300 4.0 AJ6/AJ16 head bolt re-use twice.
I don't think it applied to the V8 but I have not worked a Jaguar dealer since 2006.
Here is one of the TSBs we got from Jaguar.
bob gauff
So guys here's a new question. Got all the bolts out for the drivers side head bolts but one of them. The one is the drivers side top front 13mm bolt. Not sure if the head stripped out or what. Got a new socket and it still wont work. It gets to that really hard place then the socket just spins and the bolt just wont budge.
Even after all this I still really like this car but the motor is giving me a headache as now that bolt wont come out. Can I heat it up with a torch or will that make it worse. Need help again and sorry guys for bugging you all about my Jag 4.0 motor
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Dicque
09-19-2015 12:53 PM
al_roethlisberger
09-11-2015 10:04 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
