4.0L V8 S/C Engine
The 4.0L engines, introduced in '97 (US) came with a number of issues slowly resolved over a number of years.
The original AJ26 ('96 - '98) came with:
a water pump that failed within a couple years
a plastic cam chain tensioners that failed within a couple years
a nikasil lining to the cylinder that failed within a couple years if subjected
to high sulfur fuel
The later AJ27 engines ('99 - '02) still had the the Nikasil cylinder lining until Aug -'00 and the plastic tensioners until after Sept (Aug) '01.
Other than that they are perfectly wonderful engines.
to high sulfur fuel
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
