4.2 lower SC pulley upgrade, larger crank seal needed?
I am upgrading to the 4.2L lower supercharger pulley. Below is a picture of my existing pulley on the left and the 4.2 pulley on the right. The mating surface for the crank seal is a larger diameter on the 4.2L pulley. I don't recall seeing anything about that. Is there a different crank seal I need to get? Is this the wrong pulley?
Thanks I’ll order one. Do you remember having to swap that over when you made the change?
WaterDragon
02-12-2014 07:15 AM
