4.2 oil pan torque specs
Old 06-09-2022 | 10:02 AM
Immokaleecane83's Avatar
Default 4.2 oil pan torque specs
I have a 2004 xj8 that I'm replacing the oil pan gasket. Can anyone please tell me the torque specs for the bolts and the sequence....greatly appreciated
Old 06-09-2022 | 10:35 AM
motorcarman's Avatar
This forum section is for the 3.2/4.0 liter engine cars.
You need to ask your question in the X350 section.
It is probably the same as the 4.0 engines but I never looked up the specs.
vincent661983 (06-09-2022)
Old 06-09-2022 | 11:10 AM
thanks motorcarman....
Old 07-20-2022 | 10:03 AM
Sabrinaservicewriter's Avatar
Default oil pan torque specs
Oil Pan
Tighten the retaining bolts in the indicated sequence in two stages.
Stage 1: bolts 1 to 7, tighten .................... 5 Nm
Stage 2: bolts 1 to 17, tighten .................... 12 Nm
If you need a picture let me know!
mpasiuk
20
12-22-2021 11:15 AM
giandanielxk8
05-11-2019 08:35 PM
Jagxjs
08-24-2018 05:14 AM
kactaf
07-05-2015 02:25 PM
ArizonaJohn
03-25-2014 11:53 PM
Quick Reply: 4.2 oil pan torque specs
