4 Air Conditioning codes? Whats the common denominator??
Hello Fellow Jag people.
I have a 2002 XJR 100. The A/C codes are as follows:
41 LH fresh / recirc. motor fault Harness / connector fault Servo motor seized or sticking Flap
seized or sticking Refer to PDU
42 RH fresh / recirc. motor fault Harness / connector fault Servo motor seized or sticking Flap
45 Centre vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
46 Foot vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or
I have to think there is a common connector, relay or fuse that would cause these 4 codes all at once.
I did clear them and they all came back instantly.
Could anyone offer any help as to what and where it might be.
Thank you all.
Ted
Thank you all.
Ted
2 relays for 4 AC codes
Hi Donzi:
I get a self test code roll of 43,44,45 and 46. I found your post before deciding to go into the AC7 (it must be common) connector. But I can't find relays behind the driver's side rear seat floor area.
Can you describe the location of the relays with more detail? Did the relays have a name when you bought the replacements? Where they aftermarket or dealer units?
Best regards
George (aka OldManWithWrench)
1999 XK8 131K Bought April 2011
Best regards
xk8 vs xk6 relay location
Hi Donzi:
Thank you for replying.
Now I know why I couldn't find them - mine is an XK8 and yours is an XK6. (Time for new reading glasses)
How to find these relays on an XK8? Any suggestions? Do they have a name / numbers for searching on the JTIS?
I'm hoping I'll find them behind the driver's side cowl because getting to the vent motors is major surgery.
Hi Donzi:
I do not own an XK6, don't even know what that is...???
The relays are located where I described....in an XJ8 and an XJR
OkieTim
09-08-2015 04:48 PM
1998, 1999, ac, air, codes, coditioner, conditioner, conditioning, denominter, fault, jag, jaguar, motor, problems, vent, x308, xj8
