5HP24 easy fix? Transgo 5HP-24-PR kit
Old 05-09-2018, 02:15 PM
SBryant's Avatar
I was pointed to this thread by Sean B, after my gearbox started to have issues. I will add that the Transgo Kit can be bought via Ebay.co.uk for £25 - £35 plus shipping (varies) from US sellars
zagamuffin (06-03-2018)
  #42
Old 09-24-2021, 06:35 PM
wrd0225's Avatar
I am glad yours turned out well. I am assuming Transgo experience will go as well. The valve is in the freezer now. I will install tomorrow.
  #43
Old 09-25-2021, 03:15 PM
wrd0225's Avatar
6HP24 Transmission - How hard was it to remove fill plug?
  #44
Old 06-04-2022, 04:37 AM
St. Stephen's Avatar
Originally Posted by 64vette
I used a small piece from a welding blanket wrapped around the pipe to protect the fill tube and my knuckles from the hot pipe.
Allowed to drain overnight with the valve body removed. It took 4L to fill dry, then once running and warmed up it took another 2.2L to fill to the "steady stream" point so, 6.2L for PR valve, and filter change.
Have not driven it yet as I am inspecting and detailing undercarriage right now, and will be attempting to check differential fluid. I think cold country folks would be amazed just how clean and rust free a CA car can be underneath, even after 15 years. Edit: Differential Fill plug was actually pretty easy to R&R, I think the coupe may be easier to get to than on the convertibles although there is a substantial cross brace and the sway bar to maneuver around.
Thanks for the cold fill info.
  #45
Old 06-04-2022, 11:55 PM
Received 13,104 Likes on 6,529 Posts
Hi wrd0225,
You've posted your question in the forum for the X308, which has either the ZF 5HP24 or Mercedes-Benz W5A580/722.6. For more information on the 6HP26, see the How To / DIY thread in the stickies for the X350 forum.
Removing the fill plug on the ZF 6HP26 is not usually too difficult if you have the correct tool. On some vehicles, you can access the fill plug with a standard 8 mm Allen hex bit socket, short extension to reach past the exhaust, and a ratchet. On other vehicles, you must grind down the short leg of a standard 8 mm Allen wrench to about 2 cm - 3/4 inch in length so it will fit between the transmission and exhaust. Here's the wrench I modified for use on some X350s:
Cheers,
Don
asjdhsajhdfj
05-15-2022 03:05 PM
Len Apcar
08-07-2020 10:52 PM
jimmiejag
03-24-2018 10:40 AM
tampadamon
07-24-2017 08:41 PM
Ipc838
04-01-2012 03:54 PM
Quick Reply: 5HP24 easy fix? Transgo 5HP-24-PR kit
