60k service help
60k service help
I'm getting ready to do the 60k service on my own.
I'm curious to know what things are done at a 60k that aren't already on the schedules in my owners manual. What I read there does not equate to a $1400 dealer service.
I am handy around a wrench, I was a BMW Motorcycle and Car Master Tech before changing careers about 10 years ago. I'm pretty sure I can handle the work, but just need to know what are the right things to do.
2003 XJR w/R1 pkg.
Thanks!
2003 XJR w/R1 pkg.
Thanks!
RE: 60k service help
Thank you kind sir!
I am going to give it the full monty. I found a small squeak when lightly cornering, so I'm going to look into that while I'm in there.
Here's my plan:
Oil and filter change
diff oil change
Air and fuel filter already changed, just a week ago
Coolant change
Brake fluid flush
Spark Plugs
Reset adaptives
check all front and rear end suspension components
TB cleaning
Only one more question, what is "clean part load breather" or will I get this infofrom GTR?
Thanks again!
Andy
Here's my plan:
diff oil change
Coolant change
Brake fluid flush
Spark Plugs
Reset adaptives
TB cleaning
Thanks again!
Andy
