6240AA hubcaps - same or different between x308 / x350?
Anyone happen to know if the 6240 AA hubcaps are interchangeable between the x308 and x350? Lost one somehow off my x308 but most of the options I find online have the x350 designation. They visually appear the same at first glance but I don’t know if the size or clips might be slightly different and not fit if I try to put an x350-marked one on an x308 (though the part numbers show otherwise the same).
Thanks!
X350 marking
No X350 marking
The front, for reference - appears identical across
Thanks!
X350 marking
No X350 marking
The X350 (and S-Type) is a FORD pattern (I think it is 5 x 108mm) and the X308 is the last of the 5 on 4.75" pattern from DECADES and DECADES ago.(same as old Chevys)
The wheels are completely different so I would think they would not be compatible but?
I have a few X308 VDP wheels with no hub caps. The hub caps are worth more than the wheels!
Don B (08-01-2024)
motorcarman (08-18-2024)
24ounce
05-06-2024 08:45 AM
XJDanny
22
04-25-2017 10:20 PM
