97 XJRDrivers door catch mechanism
The internal door latch did not open door. I used external handle to open door. THEN I was stupid and pulled latch down inside the opened door. Now I can't shut the door because the latch is "locked" in closed position.
I can't drive the car as the door won't shut....the locking latches in the door are "closed" and no persuasion can move them
Can anyone help please??
Going away in 2 days and cant drive it 2000kmwith door taped up
Thank you in anticipation
Greg J
Greg J
Received 6,327 Likes
Welcome to the forum Greg, someone with knowledge of your model will be along soon enough to get you out of trouble.
post your question again in the thread below, I have listed two as there is the X308 & X300 XJR in your year.
XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
https://www.jaguarforums.com/forum/xj-x300-xjr-26/
Received 4,325 Likes
welcome to the forum, you will find a wealth of info and support here simply follow the links Clarke has provided
recommend adding a Signature to your profile including model and year to help others provide proper support to your queries. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
for info on local events, news, repair shops, etc., check out the Austrailia: Victoria/Tasmania section: Australia - Victoria / Tasmania - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy .
Enjoy .
The usual cause of the interior handle failing is the cable from it to the door latch breaks. The holiday period is not the best time to source a replacement so I expect you'll put up with opening the door with the exterior handle only until back from your trip. If you can't flip the latch back to the open position with a screwdriver whilst holding the exterior handle in the open position then the interior door card will have to come off to be able to access the door latch and operating rods.
Follow Clarke's link in post #2 to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Enjoy the forums.
Enjoy the forums.
Received 6,338 Likes
Welcome to Jaguar Forums Greg,
aholbro1
08-05-2021 05:02 AM
