98 Jaguar XJ8 Transmission Removal
Hi everyone!
The transmission in my 98 Jaguar xj8 (130,000 Mile) decided to die on me over the Christmas season. I have been scouring the internet for a guide on how to remove the transmission but have yet to find one. I was wondering if anyone had few moments to give me some instruction or if your know where I can find a guide on how to perform this feat.
As for my transmission issue, for those who want to know why I am removing it. I was on my way to work when I stopped at a stop sign. When I went to take off it felt like my wheels were spinning on ice (engine revving up and moving very slowly). Of course I live in Michigan and it just snowed the night before. I figured everything was normal. I approached a red light and stopped, when the light changed green I pushed on the gas and it felt like someone had rear ended me, the car kicked hard. As I looked at the dashboard I noticed the annoying message of "Transmission Fault". I made it to work, had the car towed to my house and that is where it has set.
I welcome any helpful advice, jokes and anything in between to help me get started. I have never removed a transmission before but I am very mechanically inclined.
-Mkvandals
-Mkvandals
Hi
Here is the weblink to the Transmission removal & install procedures (thread actually title is XJ - X308 & XJR Transmission Removal - Install extract JTIS21):
See post# 1
https://www.jaguarforums.com/forum/x...s21-faq-57639/
Also the Oil drain & refill procedures:
See post# 1 and # 3
https://www.jaguarforums.com/forum/x...ter-r-i-61563/
Jim Lombardi
See post# 1
See post# 1 and # 3
Jim Lombardi
RJ237 (01-08-2013)
There is a huge long thread where the removal and reinstallation of the transmission was recounted by one of the members with lots of input from sideline coaches. This was done on ramps, not a hoist.
It would be worth your while looking for it, even if you have to manually skim back through the threads in this section.
JTIS is fine, but it assumes a lot. The referenced thread was written by a guy in your exact position.
Hi
The DIY writeup that Plums brought your attention to I think was done by forum member sar98vdp (Scott).
Here is the weblink to that DIY on transmission rebuild PDF file that Scott created:
https://www.jaguarforums.com/forum/a...on-rebuild-pdf
Just thought I give a helping hand.
Jim Lombardi
Jim Lombardi
Thanks , well I guess I'm gonna jump off into it ,,,, was driving my 98 xj, the other day and went to accelerate , and felt like was rear ended , figure it's broken drum , went bought , a tranny with 60k on it , soooo here I go was just wondering if I was gonna have to do something to make my car know that there is nothing wrong with replacement tranny ,,,, thanks for your help ,
Make sure you use the correct type of oil for the transmission.
Original oil was Esso lt 71141, which I think is unavailable now.
Use an oil which is compatible, such as mobil1 atf, or buy from ZF dealer if there is one near you. Follow the correct procedure to fill also.
This will probably only serve to confirm some aspects and negate others about changing the transmission on a 1997-2002 non-supercharged XJ8. I read the thread with anticipation and trepidation but soon found the hysteria was all for naught; all the bolts on the bell housing are easily accessible from above and below. The most fiddly part was removing the 3 screws form the heat shield over the left catalytic converter.After unplugging the sensors on the cats and clearing the wires away, I loosened the cats on both sides by removing the 8 bolts. After raising the car (I used a lift), I removed the exhaust (straight-forward no issues) then supported the unit on a transmission jack ($150 from harbor freight and well worth it) I'd removed the top 4 bell housing bolts from above and removed the remaining ones from underneath. Then I removed the shifter and position sensors from their respective sides and put the little screws back in the holes so I knew where they were. I loosened the driveshaft and removed rear transmission support, then lowered the transmission to remove the shaft by raising it above the transmission and working it forward (easy). For ease of access I removed the 4 bolts holding the steering rack in, then removed the 3 bolts holding the flex plate to the torque converter. With an assistant the transmission was backed away from the engine. I did not remove the harness clip bar from the bell housing, no need, nor support the engine from above as recommended in the Jaguar procedure as I found it to be useless. The transmission came away with a pop as the center shaft of the torque converter separated from the flex plate.
My transmission had already be rebuilt, all clutches and baskets were intact and new. The work had been signed and dated by the technician so I contented myself with stripping the unit and cleaning the minimal dust from the inside. The problem with it was that whoever re-installed it on the car had apparently been in a hurry and had jammed the torque converter against the tangs on the primary oil pump gear, shearing them. They had friction-welded them selves to the input shaft and eventually let go. The only metal pieces loose inside the unit were the 2 tangs. I bought a rebuilt pump, complete, from Cascade for $143.50, popped it in, re-assembled the transmission and installation was pretty much a reversal of the first part. No mystery, no problems, plenty of space to work. All in all a doddle compared to doing the same job on a Mark 2,7,8,9 or X and ten times less PIA than any E-Type - and I've worked on many of each model. Fluid used was Valvoline Synthetic Foreign car/ It has the same JLM code as Pentosin, Esso and others.Just posting this to de-mystify the process. It was by far the easiest transmission I have changed on ANY Jaguar and, as long as you re-assemble the transmission vertically (make a wooden cradle out of a $4.00 Harbor Freight dolly) it goes back together very easily. Total time: 4 hours removal and re-installation, 3 hours stripping, cleaning and reassembling the unit.
Cheers,
Zaphod.
Cheers,
Zaphod.
moparmusclecars (07-25-2017)
Thanks for the reply, Larney. I have removed and replaced many transmissions, just no Jag ones. I'm thinking I can handle it. As far as rebuilding the trans, that is another story, but I just joined here. I am thinking about trying it, myself. Only issue i am told with my car from the gal i got it from is if you manually shift into low gear, it doesn't want to go. Otherwise she said its good (whatever that means).
i only have a floor jack and cedar bricks and I believe the torque converter is going out. How do I replace that single part?
Thanks is advance
Means the same as repairing the tranny, just no need to take the tranny apart. The convertor has 3 screws holding it to the flywheel/flexplate on the rear of the engine and is simply pushed onto the tranny.
Important: when removing, remove the tranny WITH the torque convertor at the same time. Then take it out of the tranny. When putting a new torque convertor in, make sure it aligns in 3 'clunks'. After the 3rd clunk it is in place. DON'T force it!
BrentGardner
28
04-26-2024 03:08 AM
Isoruku
06-19-2020 12:54 PM
Will P
08-27-2015 06:52 PM
SingBlueSilver
08-27-2015 02:20 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
