98 lug nuts...
I believe that's bad info, they aren't as robust as single piece lug nuts but they should be reusable. Several of the lug nuts on my 99 had the washers come loose which is kind of a pain to deal with but you still don't have to throw them away. I got a handful of replacements from one of the BB sponsors, sng barret for a reasonable price and replaced the ones that the washers looked loose on or had already fallen apart. I think hand tools extend the life of these parts, impacts can be pretty tough on the sheet metal covers. Some times it's tough to find a shop that wants to make adjustments for hardware though...
SNG Barratt USA (06-02-2017)
Not single use but the covers can become damaged if you try to wrench them off with the socket only halfway on the nut, making them useless (a socket will no longer fit on a deformed wheel nut cover). I purchased Eurospare part #CCC007028 replacement nuts and they work perfectly. Pricey though, about $10 per nut ($8 per nut if you buy an entire new set of 20).
