98 positive cable replacement
Hello everyone, I was wondering if anyone had advice on replacing a burnt positive cable that's located under the bonnet. I am not really mechanically inclined so, any help would be apprieciated. This was recommended by my local dealer to correct a starting issue. Battery charge is good, just wont turn over.
If you measure the lenght of that cable, any car audio shop can make for you a good quality and thick cable. They use oxigen free copper cables, that could be better than the factory one, and way cheaper.
My starter even runs faster since I installed one more thick ground cable between the battery and the body in the trunk. I connected it to the ground screw next to the factory main ground point screw.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
