98 VDP Cooling System
Old 06-12-2014 | 07:16 PM
TheHilds's Avatar
Default 98 VDP Cooling System
Does anyone know what would cause coolant to leak from in front of the front driver side wheel after putting the car in park and shutting the engine off?
Old 06-12-2014 | 07:51 PM
Rlover's Avatar
Are you sure it's coolant? Your AC evaporate drains in that location. Ifs it's stock OEM coolants its orange and not it would be green
Old 06-12-2014 | 09:00 PM
TheHilds's Avatar
Yes I am sure as the low coolant light comes on and I keep filling the tank up 2 time a day and it is a redish orange color.
Old 06-12-2014 | 09:11 PM
sparkenzap's Avatar
That is where the overflow tank is located. I suspect it is cracked
OR
Your tubes connecting to the expansion tank are swapped and the engine is blowing coolant into the overflow tank.
The following 2 users liked this post by sparkenzap:
motorcarman (06-13-2014), TheHilds (06-13-2014)
Old 06-13-2014 | 01:09 PM
TheHilds's Avatar
Thank you for the diagram. The lines were swapped. Problem fixed and the diagram also helped me order new hoses and lines that I was having a hard time purchasing.
Old 06-13-2014 | 02:14 PM
JimmyL's Avatar
Man, they should color code those coolant hoses/pipes on the coolant reservoir !
trosty
26
12-18-2022 06:40 PM
aholbro1
08-05-2021 05:02 AM
Jaguar_libra
09-10-2015 11:05 AM
Jaguar_libra
US Western
09-09-2015 04:20 PM
1100me
09-07-2015 06:26 AM
Quick Reply: 98 VDP Cooling System
