98 XJ8 Antenna not getting "remote" power
I tested the wiring that goes to the antenna, and it does not seem to be getting the 12 volt remote power that tells it to go up. I have checked the Aerial fuse in the trunk/boot and it is fine. At times, it seems as though the antenna wants to come up, but then just stops and goes back down. Any suggestions?? Is there a relay or where is the relay located if there is one?
Any help would be appreciated.
Thanks.
JP
Thanks.
JP
