98 xj8 error P1336
98 xj8 error P1336
so here is the story, I backed the car out of the garage, parked then pulled it back into the garage then the next day the thing wouldn't start and had a P1336 code(reset the code), put a new cam sensor in with no results, I then took a compression test with almost no compression so I squirted some oil in each cylinder still wouldn't start, I also noted that the tach does not move when cranking. does this meen anything to anyone?
Roy (01-26-2014)
jimforrest (uk)
02-28-2019 06:42 PM
