98 xj8--stuck lifter
The car has overhead cams. You would need to set engine in time (see thread about tensioner replacement) then remove chain from affected cam and unbolt the cam. The lifter will then come out. No need to remove head unless valve is bent. While you are in there, replace primary and secondary chains and tensioners and guides.
BrentGardner
28
04-26-2024 03:08 AM
toronadomike
03-22-2015 07:05 PM
