98 xj8 Valve cover gasket?
I think it is close. If you search, you will find a picture on this forum of one sitting in a Jag cover: some holiday at the corners, but still able to seal perfectly. Are you sure you need it? Be careful with cleaning and installing the old one (use silicon or vaseline) and be sure it seats in all the grooves and it should work. Mine doesn't leak, even at the plugs, and I have taken them off a couple of times.
These cam cover seals can be used a coiple of times if still in good condition and should be fitted dry....only using small dabs of silicon to keep the gasket in it's groove in the cover.
Spark plug well seals should always be replaced with new as they are subjected to more heat.
NEVER tighten cam cover bolts to more than 8-10nm.
aholbro1
08-05-2021 05:02 AM
