98 xj8 VDP valve cover gaskets?
I just recently replaced the gaskets on my '01. I bought the Lincoln LS kit at Advanced Auto parts (~$45 after discount) and fits perfectly. BUT this kit is known to only fit AJ27 engines! So beware - it will not fit the AJ26 engines it so appears. Best way to identify a AJ26 to AJ27 engine - I am told - is the position of whatever the true name of that valve timing sensor/solenoid is - the AJ26 is positioned on the front end side of the cover, but it's on the front end top of the cover for the AJ27.
For what this info is worth...
The original AJ26 cam covers will need the orange and grey gasket seals (one side orange and the other grey) and the spark plug rings will be 4 sets of 2 (2 rings tethered with a piece between them).
The AJ27 will have 8 separate rings for the spark plug seals and black gaskets.
The (14) fastener rubber isolators are the same for both.
bob gauff
bob gauff
Take a look at this -- https://www.jaguarforums.com/forum/x...-photos-88433/
It might help you decide what engine you have by looking at it.
Here's a suggestion -- you could buy both and bring them to the shop and then return the set that isn't used. Just make sure your mechanic only opens the set that he needs since some gasket sets are marked on the box "not returnable if opened!" Or, if you can't return the unused set, someone here would probably want it.
aholbro1
08-05-2021 05:02 AM
Dicque
09-19-2015 12:53 PM
