98 XJ8L Swapping Ignition Lock Cylinder
Old 03-24-2018, 03:21 PM
Melindasue Larrabee's Avatar
Default 98 XJ8L Swapping Ignition Lock Cylinder
Howdy y'all..been reading and enjoying. But today I've spent too much time looking for what I need to know about this swap. I saw the removal of the cylinder..but need to know about the plastic column covers. I read indelicacy can break tabs but not where they are or the best way to go about it. Also there was some question about the key reader and swapping just the cylinder. I can't find a simple illustration and don't want to proceed blind. At least not today.. and thanks for your time..
Old 03-24-2018, 03:40 PM
GGG is offline
Received 16,864 Likes on 12,186 Posts
You've already posted an Intro so I've moved your question from New Member Area - Intro a MUST to X308 forum. Members here with the same model will be able to help.
Just to clarify - you want to remove the rectangular black plastic coil covers on the camshaft covers to swap ignition coils?
Old 03-24-2018, 05:21 PM
Highhorse's Avatar
Received 1,807 Likes on 1,324 Posts
I think he's speaking of the key ignition cylinder Graham....or at least that's how it reads to me? I'm not home now, but if I recall, its just 2 screws from underneath. As for the cylinder:
1. Turn
ignition ignition
key to position one.
2. Release the retaining tang.
3. Remove the ignition switch
lock lock
cylinder.
or....
The following 2 users liked this post by Highhorse:
Don B (03-26-2018), Jhartz (03-25-2018)
Old 03-25-2018, 11:32 AM
1. Turn ignition key to position one.
3. Remove the ignition switch lock cylinder.
or....
Yes, Highhorse..I was refering to the steering column covers and ignition cylinder. But Thank you Graham for sending me in the right direction. I need more practice at navigation here. Soo, is it true then, that there will be no issue from the swapped key and cylinder with regards to the key reading system? And thankyou for the illustrations..they are now archived in my jag notebook.
Old 03-25-2018, 11:46 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Last year, I did this video...
The following 3 users liked this post by Daim:
Don B (03-26-2018), Highhorse (03-25-2018), Jhartz (03-25-2018)
Old 03-31-2018, 12:45 PM
Lock removal on youtube
I saw this video..thanks. On application there was alot in the way. I created a new tool so I wouldn't take so much apart.. Sadly the car fired up once..and then back to square one. After this snow will test the crank shaft sensor. All ready checked the inertia switch..its good. My gut says contact is not being accomplished so probably start following contact points from ignition to starter..thanks for the help!
Old 03-31-2018, 03:02 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
I have attached the cowel removal instructions from the workshop manual. They are no difficult to remove. From the sounds of your problem you may have a wire that is broken loose from the ignition switch connector plug.
The cowel is held together by 2 screws and the knobs for seat and dimmer just pull off.
Once the 2 screws are removed you need to lower the column to full down and it has to be at full extend. Some years have 2 bolts at the back of the upper cowel that can be removed once the column is fully down position. Generally the 2 cowels just separate after the screws are removed.
Old 03-31-2018, 05:42 PM
Highhorse's Avatar
Are you sure your key module is in serviceable condition ML? Has the key ever been washed accidentally or such? Do you have another key to check it with?
Don B
General Tech Help
17
08-08-2017 09:11 AM
Khello
10-31-2016 10:22 AM
Don B
General Tech Help
11-09-2015 12:59 PM
JimC64
03-02-2015 08:07 PM
05-07-2007 05:06 PM
Quick Reply: 98 XJ8L Swapping Ignition Lock Cylinder
