98 XJR Absolute throttle % never reaches 100.
My xjr feels a bit sluggish/flat sometimes in certain gears or in hot weather.
When I plugged in the scan tool, the reading on "WOT" only ever reaches 83% (with the peddle depressing the kick-down switch as far as it goes and in non sport mode).
Does anyone know if this is normal? I have had the TB off a couple of times in the last year; anyone know how to restore 100% throttle?
BTW the throttle cable is adjusted as stated in the manual.
Alex
Alex
Did you carry out a hard reset after adjusting the throttle?
I've found mid to high 90's% is as good as it gets even on the later AJ27 tb's. 100% gets you a limp mode, I've seen it and done it, it must exceed the sensors and trigger this state.
Hot weather with a supercharged car is bad news, the ignition retards to stop detonation, and this is why its sluggish compared to a cool damp air filled spring morning, a big difference.
Mods to help and some special engines have killerchiller cooling to combat the power losses.
The following 2 users liked this post by Sean B:
bagytop (07-28-2014),
xjral (07-30-2014)
On many cars (incl. my STR) the PCM watches to see the highest ever TPS and regards that as in effect 100% i.e. as WOT. You never get 100% on the sensor and it doesn't care.
I guess there's a value it does have to exceed but don't know what that is.
(It also watches the min value, which again rarely is 0%.)
(To be more correct, it watches the APP sensor(s) but think of them as TPS for this!)
xjral (07-30-2014)
Thanks chaps.
The question is, is it worth bothering with tweaks to get the thing to say "95%" throttle, or is it more likely that it already delivers "full throttle", but just doesn't say it on the scan tool?
Could I be imagining my cars lack of performance because I've had it so long?!
What oil do you use?
Preferably a high quality low friction full synthetic 5 or 10W40
Whe did you last attend to the plugs?
Make sure none of your brakes are dragging including the hand brake.
Change super charger oil and belt if necessary.
Any thing esle that is a power sapping impedance.
Always check the simple things forst to remove any power sucking impedance ;o)
Brakes, oil, air filter & plugs are all good.
If jagV8 is correct, then I am barking up the wrong tree, and the car is effectivly delivering 100% throttle (and fueling correctly for 100% throttle).
I was concerned that it was reaching 100 % throttle opening but only delivering 83% fuel!
What about a failing coolant circ pump for the intercooler? Has anyone experienced this and the associated symptoms?
When you turn the ignition on you can hear the intercooler pump running, it's located on the lhs from the front of the car on the subframe quiet low down.
The pedal percentage is nothing to do with fueling, it's just a means of monitoring.
Has it posted any codes along with the loss of power? Try it last thing at night or first thing when the air is cooler, charged cars with (H)Eaton run hot anyway, I've explained why hot weather puts a blanket on power.
My 98 XJR uses a throttle cable directly to the footpedal. I popped off the intake boot and the throttle blade was clearly not opening all the way, like 70% id say. I bumped it up a clip or 2 as stated and my car shifted down like it was supposed two and redlined all of which didn't happen before. Obviously I had a lot of slack. This is way too easy of a task.. Go mess with it for 5 minutes and see what happens..
Wolfy
05-28-2024 08:06 AM
xjrjag
09-27-2015 01:53 AM
