98 xjr codes. p0174 p0172 p0132
Old 04-02-2017, 07:12 PM
Jrp79's Avatar
Default 98 xjr codes. p0174 p0172 p0132
the 0172 and 0132 are pending.here is a pic of the ff data on the 0174
Old 04-03-2017, 01:08 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
You probably have an air leak. Rev to about 2500 parked with hot engine and if LTFTs drop you have. Looks like both banks so something common to both.
P0132 may hint at the cause or another fault.
Old 04-03-2017, 09:07 PM
Jrp79's Avatar
ok now im getting a p0172 along with the p0174 and p0132
Old 04-04-2017, 04:16 PM
Jrp79's Avatar
think I found the problem. the drivers side rear o2 sensor had a broken wire.fixed it and did a hard reset and drove for awhile and no codes except the system readiness code.would that cause all my problems and other codes?
Old 04-05-2017, 06:28 AM
JagV8's Avatar
Maybe. A few more warm ups and see.
