98 XJR HGR question
I have a 98 XJR with 78000 miles that apparently needs new head gaskets. Blowing white smoke out the exhaust and compression low on the drivers side bank. (PS bank 130, 115, 120, 115 and DS bank 90, 85, 30 and final cylinder havent checked yet ). My question is as big of a job as this is, my car has the original engine which is Nikasil. Is there any reason to choose the newer aj27 block over rebuilding my original one? Except it would be a lot cheaper to rebuild my engine since I will be doing the work myself?
If the cylinders are in good condition yet why not just replace the head gaskets after checking that the heads are not warped. There is a good chance the liners are damaged, but still worth a look.
Whether you rebuild this engine or replace it, it's a good idea to use the mls head gaskets for the 4.2L engine to limit the chance of a repeat.
If you had no nikasil issues as of yet you will most likely not. I also have to say that my nikasil block made a nice impression on me when I disassembled my motor. Cast iron/steel cylinders wear way more than nikasil as it's much harder. If you're gonna use the gasket kit we spoke about, it comes with valve seals. I'd do those if I were you as the rubber on them will be hard and brittle after so many years. Amazon has a good valve spring compressor I used for under $50 http://www.amazon.com/gp/offer-listi...&condition=new
