98 XJR trans. Does this sound right$$?
Guest
Posts: n/a
first off thanks for reading. I just bought/today/e-bay a 98XJR to say the car is mint body/interior/motor etc is an understatement.7k in work done in the past 10 months.
It has a grumbling sound coming from the transmission when it is in park and idling, goes away when in gear, shifts and drives perfectly. Any ideas?
My dealer says if it needs a rebuild it will cost 3k plus 8hrs labor. Does that sound ok?
It is being shipped as i write and will be at the dealer late Monday or Tuesday.
I wanted feed back of what might be the issue? If it is the transmission and needs to come out, should i replace anything else while the trans is down? and lastly am I paying to much for a rebuild? the labor sounds fair enough.
Thanks again.
Wasabi[:@]
Thanks again.
Wasabi[:@]
Dickie_L_J_O
09-13-2015 07:44 AM
