98xj8 starts,stops
As always, there are many possibilities. One is that the fuel pump is failing or the fuel filter needs changing. It is necessary to check the pressure at the fuel rail. We do not know your circumstances as regards mechanical experience or if you have a local shop that does your repairs and maintenance.
