99 vdp
99 vdp
I am hoping someone can tell me if there are supposed to be automatic stopping points for the sunroof function? When I press the button to close the tilt it keeps going to full open. I don't know if i need the TSP to set the timing or if it is a problem with control module. Anyone have this happen before? Also anyone have a decent place to get a sunroof seal at a good price?
Max:
You are of course right, BUT his point is well made- it is not a water seal per se, it is a wind seal at best. The seal is not designed to keep water from passing, just slow it down so the drains can handle it. And yes, it is a PITA to replace. I made a tool from a pair of what we call "gas pliers" to crimp the new one on.
Hi
The TSB that motorcarman (Bob) is referring to is tsb 501-26 Sliding Roof Diagnoisis & Repair.
It describes the major components such as Sliding Roof Control Module (SRCM), Tilt & Slide mechanisms.
Step 14 is: The SRCM should be re-timed, with the two dots aligned, (1, Illustration 9), and then installed on the assembly.
The instruction is on page 7.
The water issue fix is also on page 7:
WATER INGRESS AROUND FURFLEX SEAL.
If water is entering the sliding roof panel area by the rear of the Furflex seal, the seal must be
removed and discarded and a new seal installed, as follows ..........
Here is the weblink to the TSB:
http://www.mediafire.com/view/uq2rdy...s_&_Repair.pdf
Jim Lombardi
Jim Lombardi
TheHilds (07-15-2014)
I drive with the radio off and listen for wind noise. Maneuver between open and close til the noise is the least. I don't have any leaking issues. If you open the sunroof and push the front air dam down while driving you will hear a noticeable change min wind noise. My sun roof does not automatically stop at the perfect point.
Fletch44
09-28-2015 02:21 PM
