99 xj8 climate control issue
Weird...my ac was blowing ice cold and now its like the heat is blowing out with the AC. The compressor is fine and shows the right pressure. You can hear it come on and off like its supposed to but its like something is wrong with the climate control panel...you can turn it all the wayy up to heat and its hot as HELLLL and then its like the heat isn't turning off...you can feel a little cool air coming out of the vents with the heat. Any one had this??? What do I check?
Do a search .......the hvac system has a diagnostic program built in ... you can run different tests.
These systems are rather complicated -- with many sensors as well as flaps and motors. You should be able to feel the different hose and determine how cold the ac system is as well as the hose to and from the heater core.
You can get the Diagnostic Trouble Codes using THIS FILE. Also, THIS LINK has all the Climate Control files I've got saved. Hopefully, something in there will help.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
