99 xj8 computer reset
Old 08-15-2014, 08:09 PM
avfromvt's Avatar
Default 99 xj8 computer reset
So I was getting a code I could not clear with the code reader and I took the car to a local mechanic who supposedly had previously worked on several Jaguars. After a month he told me he could do nothing. When I started the car it was throwing all sort of errors, traction control fail, stability control fail, etc..... Needless to say after an argument he assured me those codes were on when he got it. It has been a few weeks and I am unable to clear the codes. Besides disconnecting the battery is there a factory reset on the computer??? What should I do next?
Old 08-17-2014, 02:02 AM
flatsix's Avatar
first i would check battery capacity, bad battery performance causes various fault codes. as i experienced recently the jag diagnostic system is a bit special, so i recommend to see an offical dealer or a shop that has acces to the original jag diagnostic tool to clear all the fault codes.
Old 08-17-2014, 04:10 AM
Gippsland's Avatar
Just a thought,
Some recommend disconnecting the battery leads and holding them together (just the pos and neg ends) for a minute.
Supposed to negate any residual power in the system. I have tried this with no adverse side affects/no actual benefits either from what I could see apart from losing the failsafe only to have reappear later. Then able to track that code.
Rightly or wrongly this advise came from a Jag mechanic.
Are you saying your OB11 reads the codes but will not clear them to see if they reappear?
Old 08-17-2014, 06:47 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Originally Posted by avfromvt
So I was getting a code I could not clear with the code reader ..........
I've moved your question from General Tech Help to X308 forum. This is the place to post questions about your model.
Old 08-17-2014, 09:16 AM
Received 8,106 Likes on 4,891 Posts
No Generic code scanner/reader is going to clear 'C' codes (CHASSIS) for the ABS/TRAC faults.
Generic code readers are for 'P' codes (POWERTRAIN).
The type of diagnostic equipment needed to diagnose your fault has been beaten-to-death on this and other forums.
You need to search for diagnosing chassis codes (or body codes etc.)
WDS, IDS, Autologic, AutoEnginuity etc.
bob gauff
CClifton
03-19-2017 02:25 PM
Will P
09-30-2015 08:38 AM
flyrr100
09-29-2015 03:47 PM
Jpav27
09-26-2015 03:33 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Quick Reply: 99 xj8 computer reset
