99 XJ8 Front suspension
Hi guys. Got a question a long with some info. Our 99 XJ8 is in need of a new front shock mount. Originally I thought it was just the shock, I changed the shock (will upload how-to video later), which helped, but the main problem is the shcok mount. The rubber/ foam-type bushing is worn down just enough to give me some horrible clunking on every little bump. I've seen that I can replace the whole mount easy enough for about $300, but I have some other idea first. 1st there is just enough space to fill the gap by squeezing some other material in there and then tightening down the top nut. I practiced the theory with an old cotton rag earlier and it actually worked pretty well. Didn't stop clunking on big bumps, but stop all the little ones. I'm wondering if anyone else has tried anything like this with success before? Second, I see kits for $100 on ebay that supposedly work, but not sure how/ if its worth it. I have no problem spending the $300 if I have to, but If I can save $200-$300 and get the same results I think it might be worth a try. Just don't want to buy one of these ebay kits only to find out that I have to spend $300 on the whole mount after the fact. Any ideas or opinions? I'll post a video tonight or tomorrow. I too a video as I replaced the shock and then after I ghetto-rigged my mount and took it for a ride. Thanks guys.
I'm sure you can get the upper bush kits instead of the whole mount, this is what we buy in the UK. It's a common problem, the kits are the way to go. One of our sponsors should see you right.
I'd not use a pair of knickers wrapped round it though, or a stocking on the supercharger!
Hope this helps.
Hope this helps.
Swick: Put your wallet away. Unless your upper mount is rusted away, which it doesn't sound like. All you need is an upper bushing kit, comes with four bushings, washers, and nuts. Welsh Ent. has them for about 85.00 PN: MNC-2168-69-K 1-800-875-5247, or Ken @ Motorcars Ltd. for about the same price. Ordered mine, have yet to install. Enjoy.
Thanks Rae, yeah I've been seeing these on ebay, hoping someone whose installed them can offer some feedback. Do you know how to get them on? I'm wondering if I have to cut the old one off and maybe the new bushing is cut to put it done and tighten down?
Dan R & Swick: A valid question Dan. I opened up the pkg and read the very brief instructions. It would appear you do need to remove the upper mount housing/bracket from the car and indeed, they say to use a press to remove and install new bushings. No cutting required Swick. Would defeat the purpose of having a sound new one in place. I may be naive here, but I can't see why a work around can't be had somewhere in ones garage, I'm on the road for the next three weeks, but I will get to this ASAP and give update when I do accomplish. I figured it would be like all other cars, where you just swap out top rubber mounts as if they were washers. Foolish me.
Received 2,193 Likes
I replace those with motorcars kit all the time. Yes i use a press to pop them apart, but really a b.f.h. Will do the same all you need is the 10mm bolt for driving apart. I then line the metal pieces up and tap them back together by hand with small hammer and put the mounts back on the car.
The following 2 users liked this post by Brutal:
Alvin Burns (05-12-2011),
Boomer from Boston (05-04-2011)
is this the source of a clunk?
Hello JF could you tell me is this a subframe mount bushing? because they are both torn really bad...causing nasty clunks and the steering is causing to pull hard on the road. i was going to replace the front shocks figure ill tackle everything while im there..and if i do replace do I need an alignment aGAIN?
THANKS AGAIN jf YOUR ROCK!!!!
yes my alignment is shot I recently did them 8 months ago.I noticed my outer tire wearing out..along with drifting while steering and the vibration at high speeds in the rear and front .I have a feeling the rear might need changing I notice play on my driver side rear. .
I decided to go with PowerflexUSA lower control arm bushings I prefer stiffer rides and control.
I hope I did good..is there a DIY forum on this one anywhere here?
thx Brutal your always on top and again Thank you JF!
Ouch, not too bad but I just bought a set from Coventry West for $100, not $85 but still far less than the $300 plus per side from the dealer I suppose.
Swick, hopefully your subframe bushings aren't blown out, they are on my XJR and will probably be doing them next week.
Also wondering, does anyone have any video on this job yet? Thanks.
Good luck. I just wound up buying a whole new shock mount. It literally took less than 10 minutes to swap, my one complaint is that the lower hole on the new mount did not line up perfectly, but I just tightened up the remaing bolts real good and left that one out. I'm sure I could have sent it back for an exchange but once its on its not going any where. I may have ordered it from rocketauto.com, I don't remember off the top of my head, but pretty sure it was less than $300, and fully assemebled with top and bottom bushings. I know guys on here talk about doing it with after market bushing for $100, but I'm just glad to have it done, and seriously, it took less than 10 minutes, that in itself is worth the extra money to me.
Swick, at 11:12 into your video you point to the bushings. Both of mine on my 98 XJR look just like yours. I have two questions for the experts...
Can those be ordered and replaced by a novice? Do they have to be replaced while there is no weight on the front tires?
Thanks in advance,
-David.
Thanks in advance,
-David.
swick, at 11:12 into your video you point to the bushings. Both of mine on my 98 xjr look just like yours. I have two questions for the experts...
Thanks in advance,
-david.
Thanks in advance,
-david.
Mugatu
22
06-23-2020 01:50 PM
02jagstype
09-04-2015 08:20 PM
