99 XJ8 intermittent issue car only cranks but doesn't start
I had similar issue that the car 04 XJR would not start. Turned over, spark, fuel pressure all good NO codes!! Many frustrating hours over a few days it finally came down to being coolant had seeped THROUGH the sensor into the connector coroding it ( no visable leaks).
New sensor and connector pigtail (NAPA sourced) changed. Started right up first turn.
ECU needs to know engine temp apparently as a given to do anything!!
