99 XJ8 Left side 2ndary chain Broken
HI Guys, My beloved XJ8 is down. The plastic tensioner failed and jammed itself btw then chain and the procket. The 2ndary chain snapped during start up after getting gas. Question: Is there an easy way to find out if I have damaged valves? I'm hoping I can replace the chain and tensioners to get my kitty back on the road. I looked in the search field but didnt find a way that I could check myself. Thanks in advance
Yes. There is only the one chain broken, between the two camshafts on that side, correct? The exhaust cam is driven by the sprocket on the intake. You will have to remove that chain. When you get the exhaust cam to the position where it is not touching the valve buckets, look at each valve bucket. If there are any depressed into the head, probably a bent valve.
Tar
09-06-2015 11:24 AM
