99 xj8 pcv problem
Old 02-17-2008 | 11:19 AM
steve's Avatar
Default 99 xj8 pcv problem
Hi does anyone have a copy of the tsb for the clogged l/s valae cover
Old 02-17-2008 | 11:27 AM
jag_genius's Avatar
Default RE: 99 xj8 pcv problem
not on me.. website is down.. you just pop the hose off d/s and with mechanics wire or a drill bit.. stick it in and make sure it is not clogged up
Old 02-17-2008 | 10:32 PM
ibjags's Avatar
Ive been using the end of antenna mast for years
same diameter as whats called for and no worry of drill bit falling into cam cover
Tony at Jag school thaught i was nuts till he mic"d the diameter and it was the same as whats called for for in the TB
Old 02-18-2008 | 07:20 AM
FactoryJaguarTech's Avatar
Lol I would have called you nuts too. If tony says ok, good enough for me!!
SteveSheldon
UK & Eire
505
07-14-2016 05:48 AM
jdzubas
10-04-2015 10:14 AM
jimbo1948
09-07-2015 04:14 AM
obwoodie
09-03-2015 08:45 PM
laserguy
09-03-2015 03:02 PM
