99 XJ8 - Timing Parts List
Hi All,
After much reading on this forum (thanks for all the helpful info!), JTIS, AllData, etc I wanted to put together a parts list to perform the dreaded Timing Chain, Tensioner and Guide replacement since the PO didn't update the tensioners.
Prefer to use OE (from Forum Sponsors) and get all done in one job.
Below is a list of OE part numbers, quantities and descriptions. Considering adding some 'extra' bolts for any items that might strip/break off during this procedure, open to suggestions. IMHO the worst feeling is when you are 95% complete with the car only find out you have to special order a screw/gasket and wait 5 days to complete the job.
Based on the below, anything that might be missing or you would recommend adding?
Thanks for any input!
CHAINS / TENSIONERS / GUIDES
EAZ1286 Timing Chain Primary x 2
EAZ1269 Timing Chain Secondary x 2
AJ82325 Tensioner Primary x 2
C2Z2642 Tensioner Primary Bolts x 4
C2A1511 Tensioner Secondary Left
C2A1512 Tensioner Secondary Right
JFB10607B Tensioner Secondary bolts x 4
NCA1998AB Chain Guide x 2
NCA2025AB Chain Guide x 2
VALVE COVER GASKETS
AJ88285 Cam Valve Cover Gasket Left
AJ88400 Cam Valve Cover Gasket Right
AJ87206 Spark Plug Tube Seal Inner x 8
AJ87242 Spark Plug Seal Center x 4
NCA2575CA Camshaft Cover Grommet x 28
AJ82856 Valve Cover VVT O-Ring x 2
BUSH CARRIER GASKETS
NNE2622BA O-Ring VVT Bush Carrier (2 Each Side) x 4
KSH108624 O-Ring Bush Carrier x 2
CRANKSHAFT SEAL / TIMING COVER SEALS
AJ83698 Front Crank Seal
AJ89909 Front Crankshaft Bolt
AJ89854 Front Crankshaft Split Cone (Collet-Split)
XR81139 Front CrankShaft O-Ring
AJ83700 Timing Cover Gasket - Outer
AJ83699 Timing Cover Gasket - Inner
KSC145624 Timing Cover O-Ring x 2
OIL PAN SEALS / FILTER
NCA1730AD Lower Oil Pan Gasket
EAZ1354 Oil Filter
MISCELLANEOUS
Loctite Ultra Gray 5699 RTV
VALVE COVER GASKETS
EAZ1354 Oil Filter
MISCELLANEOUS
jagslinger (10-03-2014)
You must like working on cars. I only replaced the secondaries, thermostat housing and water pump. Good idea to get the aluminum thermo housing, Welsh Ent. has a good one with new thermostat.
Also suggest the transmission control valve replacement:
http://jagrepair.com/images/AutoRepa...%20ZF5HP24.pdf
http://www.thectsc.com/products/main...p30-81-32.html
and fasteners:
Oil Pan Screw 5HP19 and 5HP24
and fasteners:
cobac (09-02-2014)
Here is a JPEG file that I created showing your list and a list from Christopher's Foreign Car Parts website:
![](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/93814d1408676547-99-xj8-timing-parts-list-x308-timing-chains-tensioners-primary-secondary-parts-list.jpg)
You should also look at this DIY - has instructions and Photos:
Tmingi chain and tensioner replacement
Jim Lombardi
Jim Lombardi
cobac (09-02-2014)
Thanks RJ & JL, this information is really helpful -- Appreciate the comparison!
Like working on Jags, but am dreading this dismantle, especially after reading all of the horrors of removing the crankshaft & bolt. Figured it was better to just do it all at once the engine was opened, but am actually reconsidering doing only the secondaries for now. The car has been sitting because it started the rattle on a cold start and I'm afraid to start it up again until I can get the covers open.
Probably get the secondaries done quickly and get it back on the road and consider doing the other tensioners/chains once I solve the transmission issue of intermittently slipping when accelerating from a stop sign which I'm hoping is just a replacement of the valve body![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks again!
Thanks again!
Will P
08-27-2015 06:52 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
