99 XJ8 trans fluid and filter change question
When changing trans filter and fluid in audi a6 i had to have the vehicle level on jack stands, running, once the cooling fans kicked on, then i would check the trans fluid level and add as needed. I could not find in the thread if the same procedure was needed for the XJ8. When verifing fluid level after change, is there a set procedure? I have a 99 XJ8 base model.
thanks for your input.
hunt
hunt
Received 6,361 Likes
Transmission ZF5HP24 Fuild & Filter R&I PDF files
Hello
Thank you Norri - The ZF5HP24 thread has the Fluid Drain & Refill procedure, but I noticed that I should have included the Filter removal & install PDF in that thread.
Here are 2 PDF files that cover ZF5HP24 Transmission Fluid & Filter replacement:
First one has instructions and illustrations on the Transmission Fluid Drain and Refill procedure:
https://www.jaguarforums.com/forum/a...l-44-24-02-pdf
Also you should look at these other 2 transmission fluid fill threads (since most of us do not have a PDU - Portable Diagnostic Unit - that the instructions in PDF file calls out):
https://www.jaguarforums.com/forum/x...ns-help-36256/
https://www.jaguarforums.com/forum/x...acement-61555/
The other one shows the Transmission Filter and instructions on its removal and installation:
XJ (X308) ZF5HP24 Transmission Filter R&I.pdf
Jim Lombardi
Jim Lombardi
Last edited by jimlombardi; 08-18-2012 at 09:12 AM. Reason: Added weblink to a refill thread
MC36
US Lower Atlantic
09-01-2015 07:34 PM
