99' XJ8 Transmission Woes
Guest
Posts: n/a
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
My son took our 99' out several times last month and came home to report it won't go into forward gear without rev'ing the engine and then it clunks into gear and drives mushy...goes into reverse ok. I cruised the threads and someone suggested dropping the trans oil pan and look for metal. Unfortunately, I found an assortment (picture attached). Is this terminal for this transmission? Can any repairs/replacement be done without removing the transmission? I would appreciate any and all help/suggestions...thanks, Tod Rankin
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Probably from an 'A' drum failure. See the pictures on post #17 at this link:
https://www.jaguarforums.com/forum/s...ad.php?t=29038
Good discussion on the problem. Solution is a complete rebuild. Sorry.
aholbro1
08-05-2021 05:02 AM
