99 XJ8 VDP: Ideas for USB charger port location?
At some point, I'd like to install one or two USB ports, for device charging, somewhere more discreet than using the lighter plug and long cords (my phone is on a window suction-mount, near the middle.
One thought I had was putting a single port below the clock, and between the minus and plus buttons, however, I have never pulled the clock out, so I don't know what kind of cavity exists, if any.
Anybody have other ideas, or have you removed the clock before and can tell me how feasible that idea is?
Hey buddy that's great idea! I do would like to insert a USB port ! Under the clock would be ideal for just a USB stick tho for your aftermarket stereo (if no port on the face of stereo) how ever I myself wouldn't see the point of it under the clock to charge cellphones as it does not minimize the cord factor! I will be brainstorming of some spots to place! Look forward to any other ideas posted aswell
I'm only interested in a charging port, because I use bluetooth to play my music.
Received 1,796 Likes
I put my usb in my center council from my head unit. This way no one can see my charging or stereo connected device and its clean. The area under the shifter and either side is real easy to feed wire under. Plus you can tap off of the existing cig lighter and hide the other one under the council (not in the storage box) and put the usb through a small hole in the bottom corner of the box. It becomes real assessable there also, no reaching over to the glove box.
The center council comes off real easy, 4 screws (2 front, 2 back) and the whole box and lid lift right out. You can get an aux cig light from the Rat Shak.
For my situation, putting it under the clock dramatically minimizes the cord factor. Right now, I require about a 4 foot cord, draped across the shifter, the radio, and the climate control, in order to plug into my phone which is on a suction mount at the center of the window. A cord from the clock to the same location would require about one foot going past the clock and into the phone.
This doesn't sound like what you are looking for, and the interior of the X300 is somewhat different, but it may perhaps spur your creativity:
https://www.jaguarforums.com/forum/x...-ideas-105768/
I thought the ashtray area would be a good place for this, much like what can be seen in the link. An extreme way of doing it would be to feed a wire to come through the demister vents to link up with your screen mount, that way you would have a very short and minimised cable factor indeed.
Dicque
09-19-2015 12:53 PM
jagent
09-12-2015 01:40 AM
