99 xj8 won't start. Anyone have this situation?
Hi to everyone. Please don't be cruel! I am a woman and not any mechanic, at that. I have searched the forum and can't find anything particularly helpful with my car's no start situation. If you're easily irritated, move on. Lol! I'm new here and not skilled. If you're still with me, let me explain. I appreciate all input. 😊
-99 XJ8, purchased a little over a year ago, battery less than one year old. Battery replaced less than a yr ago new.
- car will or start but did a week ago. Key turns in the ignition and all interior accessories work right away. The engine does not crank so does nothing.
- dash indicators: everything lights up like a Christmas tree. The msgs will scroll, more or less, as follows: system check, stability control failure, traction control failure, check engine, trunk open... Basically like that. (Trunk thing has happened forever, not worried about that)
- what have I tried? I tried to start with the spare key. (No valet key here), I attempted starting in neutral with the brake on (some advice I got), disconnected battery cables and left them off for 30 mins then reconnected them. No go with any of those.
Ive asked around a little.. I'm so minimally skilled! Any tips? Have you had this? I think I will have to tow at this point to a mechanic, ugh. nearest Jag dealership is an hour and a half away. I can get the tow and get it to the best nearby place but I. Just want to know wth?! 😊
Welcome ! These cars' are very sensitive to voltage issues so a healthy battery is a must, regardless of age have yours tested. Hard resets clear capacitors & remove many gremlins.
Hard Reset :
1. Turn Key OFF
2. Remove Negative Battery Terminal from the Negative Battery Post (10mm Wrench)
3. Turn Key ON
4. Touch Negative Terminal End to Positive Terminal End and hold there for 15 'ish seconds (Positive Terminal will still be connected to Positive Battery Post)
5. Turn Key OFF
6. Reconnect Negative Battery Terminal back to Negative Battery Post
NOTICE:
On First Start after the Hard Reset, let the car idle for a minute or two without touching throttle. This allows the computers to recalculate the throttle position, etc... Also, the car may drive differently for an hour or so while it's relearning your driving habits
Hard Reset :
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
NOTICE:
Lady Penelope (08-07-2019)
It is possible that, after the car sat for a week, the battery went very low. The first thing to check is measure the voltage on the battery terminals (there is no need to disconnect the cables). If you don't have a multimeter, asked somebody to do the voltage check for you. Let us know what reading you get.
Thanks, guys. Although I still don't know anything for sure, asking here and with some advice from a local guy, only by messages, this very well could be a battery issue, even though the battery is far from old. The car doesn't get driven very often, well, it hasn't this 3 months of summer. It only goes on short trips once a week, twice at best. The electrical load on this car must be huge. Lol! Alright, I can try what King Charles suggested. I'll probably be well off just getting voltage tested. That's a little trickier since I don't have the stuff and I'm dead in the driveway. Lol! I do appreciate the advice! Anyone can keep it coming. I've got a good day or two before I resort to a dreaded tow to the shop. Much appreciated! I'll update later, for sure.
If the voltage check shows 12V or less, the battery badly needs to be charged. Before connecting a battery charger to it, disconnect the negative cable and re-connect it once the battery charging is completed and the charger disconnected.
On the X308 it has a history of the 2 nuts on the fuse link coming loose
This is just after the positive battery terminal post
Verify the starter solenoid relay clicks with your finger on it and if not it can be swapped
The relay is on the right side of the engine bay on a LWD American car
With the multiple messages could be one of the " king Relays " that close to bring power to the different points on the car at the fuse boxes is not getting its close command ground from the ignition switch
see page 31 and 36
http://www.jagrepair.com/images/Auto.../jagxj1999.pdf
The ignition switch that closes these relays is easy to get to and test , but the king relays circled in red can be pulled out a bit and be rocked in their sockets with the key on to feel them click closed by the ground command from the ignition switch
You can do this yourself with the key on , engine not running
see page 31 and 36
Mike Leon
General Tech Help
10-07-2017 05:24 PM
worldpower
09-15-2007 11:29 PM
