99 XJR Major Coolant Leak
Just like to know if you ever drained your radiator if so I wanted to know there is a plastic wing nut on the dirvers side facing the engine is that a drain plug if so is there a seal for it I have a leak and I would hate to fork out 800 to 1000 for a radiator with a minor problem like this thanks
JoyskiXJR
Part # is WJ106001J (Radiator Drain Plug seal) - Jaguar Classic Parts shows that 2 of them are required??
Here is the weblink to their parts listing showing the seals:
Radiator and Pump-Supercharger - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
Jim Lombardi
Jim Lombardi
#30
part number
JoyskiXJR
Jim Lombardi
Jim Lombardi
#31
Further help with Norma leak
I've googled around but I'm missing the key wording apparently... Can you or someone out there point me in the right direction for curing a big time leak from the infamous Norma connector on my '00 XJR? I care more about a good working fix than keeping everything original (for what it's worth).
#32
You *can* try to repair it with parts and hoses from the auto parts store, but I wouldn't want to go through the trouble and have an old section leak or burst after the repair, so I ALWAYS opt to spend the $$ to buy the octopus hose. An I am one cheap fellow.
Might I also recommend removing the supercharger at the same time and replacing the hoses underneath? They are very inexpensive, and it makes both fixes easier if you do it that way.
Might I suggest you open a new thread? That way we can work with you on your specific issue.
OkieTim
09-08-2015 04:48 PM
1999, 2000, 2001, areas, connection, coolant, electrical, intak, jaguar, leak, leaking, supercharged, tranmission, xj8, xjr
