99 XJR - problems on motorway
I have a 1999 XJR with approximately 80,000 miles which I bought earlier this year. I have experienced two problems while driving on the motorway.
1. At approximately 65mph+, the cabin will vibrate intermittently - it occurs during acceleration, while holding a steady speed, and while decelerating. The vibration tends to worsen at higher speeds. I have had the wheels balanced, but the problem persists.
2. The engine coolant temperature is very low while running at motorway speeds: it is generally on the border with the blue segment. On one occasion, it fell right to the bottom and an orange warning light and "Restricted Performance" appeared.
Has anyone experienced either or both of these problems, and if so what is the solution?
Many thanks for any assistance.
+1 on the driveshaft coupler. Even though the car has relatively low mileage, it's also the age of these cars that reek havoc on the materials hence the rubber couplers are no longer pliable and turn hard as a rock. Or you may also have a coupler just coming apart.
Sounds like your thermostat is stuck open.
The thermostat is intended to have a rubber gasket around it, to get a good seal. I had a problem where the thermostat was working OK, but the gasket was not installed, so enough water was leaking past to make warm up very slow, and in cold weather on the highway the engine would start cooling down.
