99 XJR steering wheel tilt fuse keeps blowing
You can disconnect the tilt motor connector and measure the resistance but I would just suggest that you remove the motor. The 'tilt' is a lot easier than the 'reach'.
At the top of the XK8/R forum there is a FAQ Sticky that has most of the reoccurring issues with these cars listed in alphabetical order, along with a ton of documentation and reference material. At the top of the 'General Tech Help' there is a Sticky that provides a free down load of the JTIS CD. That is the official Jaguar repair and service manual.
Two specific links in the FAQ Sticky relating to tilt/reach problems are:
https://www.jaguarforums.com/forum/s...highlight=tilt
https://www.jaguarforums.com/forum/s...ad.php?t=17191
ebuzz22 (11-24-2010)
Received 2,193 Likes
The following 2 users liked this post by Brutal:
ebuzz22 (11-24-2010),
test point (11-24-2010)
hunter34
19
09-14-2022 11:09 PM
