99xjr goes into limp mode when put into reverse.
The car will seem to engage reverse hard and if it does then transmission fault will display and the vehicle will only drive in limp mode ( no power and acceleration)
it does not always do this, there can be a couple of days at a time when everything is fine, and then the problem resurfaces.
it only happens when selecting reverse.
When the problem has not occurred the car shifts perfectly and sport mode works fine.
this has been going on for about a year now with no change. There is no deterioration in the way the car shifts ( unless the fault light shows up in reverse as described) so it’s
hard for me to see this as a transmission problem
All fluids are new and full and the car just turned over 100k
The linear switch has electronics inside so the problem could also be there. Possibly deteriorated solders causing intermittent loss of contact; or an electronic component on the way out.
I think is is an electrical issue too, it is also intermittent. It happens almost always on engaging reverse on cold start up, but it can also happen after the car is warm as well.
every time it happens it feels like it shifts hard into reverse, as if the transmission is getting the wrong signal somehow. The car never shifts hard at any other time and never in forward gears.
then there are other times when I put it in reverse and is goes in gently and the fault does not occur.
It seems there are two types of limp modes, mechanical and electronic
Electronic would keep the vehicle in the selected gear until switched off and after that it would operate in second and reverse only.
that is definitely not what is happening in my case.
Mechanical would shift into third gear only and remain there. This is also not what my car is doing.
With my car the message “ transmission fault” will show on the dash ( most times without the engine light coming on) and the car will shift normally but with limited power ( and sport mode will not work)
this appears to be what should happen with P0705 codec due to the dual linear switch signal malfunction according to the bulletin
once I switch off the engine and wait a few seconds it will run perfectly normally again.
sometimes it will still be in limp mode when I turn it back on and I will have to turn it off and restart to get it back to normal.
does that make sense to anyone?
arfzx
04-22-2009 10:41 PM
