99XJR, thick cloud of smoke when first starting the car but goes away right after
Just started a few days ago. If the car sits for more than about 12 hrs, a thick white/gray cloud of smoke will occue when I start the car but will go away right after and wont smoke anymore untill i shut the car off and have it sit again for over 12 hrs. The car drives and feels fine, what could this be?
Just a note of advice: reading what is going on with your particular engine is going to tell you alot more than reading posts by others who have solved loosely related problems. For example, pcmcmillan had a ring/ piston problem. Poboyblue's advice about PCV/ oil baffle problems was specific to 4.2 engines. Yours sounds more like a head gasket, and testing for the fault is the only good way to identify what is causing your symptoms.
Paradigm
06-15-2019 06:59 AM
1964Daimler
09-03-2015 12:41 AM
