I searched the forums and know there is a solder fix for the module.I inherited this car with the ABS/Trac light already on & had a independent shop pull the codes.I'll post them below can the car be driven without the ABS installed if I take it out & have it repaired and any deciphering of the errors would be helpful.Also what are the average costs to repair the ABS I will not be doing it myself.
